I'm not sure which Progress springs you're using exactly, but I know they make some specifically for the H22 into EG swap, so you may want to look into those. They sell them on Hasport's site.
Unless you're using the ones specifically designed for the H22 swap then yeah, you're probably gonna get some sagging in the front end. You'll just have to see how bad it is and whether the performance/height is acceptable to you or not...
Yeah, the springs Progress makes for the H22 swap are wound 150 lbs tighter in the front then your current ones are, so there will probably be some sagging for sure...
