I'm in the process of doing a b16 swap into my ek.
I've researched the forums and found out alot of what I got to do.
I got a couple of problems though:
1: doing the iacv 3 wire to 2 wire fix and the wires are different colours. I know pissedoffsol's thread said to connect the yellow/black wire to the green/black and connect the blue/black to black.
my obd1 wires are yellow/black and blue/yellow and my obd2a wires are black/yellow and blue/black....which ones do I connect to which?( i disregarded the orange wire)
2. Also rewireing the alternator and some of the wires don't match up. I got the colour codes from the other two threads on the alternator wiring but my obd2a plug only has 3 wires as for the obd1 has 4 wires...everything matched except there was no white/green wire to go to the white/yellow wire on the obd1 plug. I was left with the white/red wire on my obd2a harness and the white/yellow wire and one other wire from the obd1 plug
I'm stuck on these two so all the help would be awsome
Thanks
Thanks
