Facebook Twitter
DC2 Integra to EG Civic Suspension Swap
This is a discussion on DC2 Integra to EG Civic Suspension Swap in the HYBRID -> EG-EK / DC forum
Donor car is a '95 Integra GSR. Receiving car is a '93 Civic Si coupe. I want to know how much of the Integra will swap over to the Civic. So far I know the GSR and Si/EX use the same knuckles which accept the ...
Old 09-08-2011, 12:33 AM   #1
GlassHeadlights's Avatar
Default DC2 Integra to EG Civic Suspension Swap
So far I know the GSR and Si/EX use the same knuckles which accept the GSR brakes. I also get to use the GSR front and rear sway bars, under hood strut bar and rear trailing arms with disc brakes.
Can I use the front subframe off the Integra? It has a stabilizer bar running parallel with the steering rack that isn't on the Civic. Some say the Integra steering rack will have a closer ratio too.
Can I use the upper & lower control arms aswell?
The Civic will also be receiving the GSR motor if that helps.
R.I.P. Short Lived '95 DC2 GSR http://hondaswap.com/auto-multi-medi...8/#post1722934
'93 Civic Coupe Si http://hondaswap.com/auto-multi-medi...5/#post1727322
Originally Posted by invisibledemon View Post
..we generally don't take each other too seriously here.
GlassHeadlights is offline   Reply With Quote
Old 09-08-2011, 12:43 AM   #2
My ideal plan was to put the Civic parts back on the Integra so I can roll the shell around.
Old 09-08-2011, 09:50 AM   #3
eg6sir's Avatar
everything should swap right over.. i mean everything.. not sure about the front subframe though
eg6sir is offline   Reply With Quote
Old 09-08-2011, 11:45 PM   #4
Some people online said they have done the subframe swap and its a direct replacement. You have to use Si/EX knuckles and LCAs or all Integra parts, DX Civic stuff won't work.
Only one way to find out for sure!
Old 09-09-2011, 07:44 AM   #5
eg6sir's Avatar
do it.. it'll be an integra w/ a civic body when you're done
suspension integra 90-93 vs civic 92-95 tieu1991 Wheels / Suspension / Tires / Brakes 3 05-27-2010 07:55 PM
93 Acura Integra GSR 90 Honda CRX HF Suspension Swap gsrx Wheels / Suspension / Tires / Brakes 2 02-23-2009 09:49 PM
Brake/Suspension Swap on 90 Civic HB Aquariust Wheels / Suspension / Tires / Brakes 7 01-17-2004 10:49 PM
Suspension for a 92 Civic HB DX WITH GSR SWAP illmatik Wheels / Suspension / Tires / Brakes 1 12-07-2003 11:29 PM
Integra Suspension In Civic aznhottiekj Wheels / Suspension / Tires / Brakes 1 02-08-2003 08:42 PM
© 2001-2013 HondaSwap.com
