Go Back   HondaSwap Forums > Technical Articles and Reference > Swap Articles
B Serires into EK Civic
Old 04-23-2005, 02:46 PM   #1
Rep Power: 12 Tim@Canspeed.com is off the scale
Assuming you will be using the same vintage drivetrain as the car here are the Honda part numbers for the 3 main mounts you will require.
All mounts from 99-00 Honda Civic SiR (US Si)
Note: The transmission mounts are for the 99-00 SiR tranny. If someone could confirm that they would also fit the Integra transmissions it would make this thread more usefull! the T-Belt mount will fit any B Series engine however.)
Timing Belt Mount
Part # 11910-P30-000
(Mount bolts to the block underneath the timimg belt cover)
Transmission Mount (top) **Update: All hydraulic trans use the same mount, therefore this mount is not required**
Part # 50825-S04-000
Rear Mount (t-shaped bracket)
Part # 50827-S04-N10
Torque Mounts left/right
I don't have these part numbers. If anyone can contribute it would be appreciated.
The transmission torque mount required will be for any Integra 94-up and Civic Si (Canadian SiR) 99-00. The A/C torque mount will be specific to the engine you have.
All three mounts retail for about $200.00 CDN direct from Honda.
Perfect Power Canada - National Distributor
<a href=\'http://www.perfectpower.ca\' target=\'_blank\'>http://www.perfectpower.ca</a>
Tim@Canspeed.com is offline   Reply With Quote
