DPFI to MPFI Conversion
How to Convert DPFI TO MPFI: A Wiring Guide​
SUPPLIES:​
  • 1 black 0BD0 ecu connector w/ pins
  • 1 0BD0 MPFI engine harness
  • Distributor plug w/ wires
  • 1 0BD0 MPFI ECU
  • 1 Injector resistor box (w/ enough wire to solder to)
  • Various wires in colors close to factory colors as possible
  • heat shrink tubing
  • electrical tape
  • soldering iron/solder/equipment
Wiring:​
Refer to the above diagram for more details on location and colors
A1 - BROWN
A3 - RED
A5 - BLUE
A7 - YELLOW
INJ TO RES BLK/RED
RES TO Al5 BLK/YEL
Move wire from Cl to B10 ORANGE
Move wire from C2 to B12 WHITE
Pins C1 & C2 are now empty
From C1 run a BLU/GRN wire into the engine bay
From C2 run a BLU/YEL wire into the engine bay
Honda DPFI to MPFI Conversion
Honda OBD0 DPFI to MPFI Wiring
*I advise you to put the connectors near the firewall for the new wires you run for future engine removal. This is not a must, but may be helpful*
* To avoid headaches, be sure to leave yourself enough wire slack for both routing and soldering*
Injector Wiring​
Injector sequence:
Looking from the front of the car,
Distributor #4 #3 #2 #1 TIMING BELT
From Al run a brown wire to inj #1
From A3 run a red wire to inj #2
From A5 run a blue wire to inj #3
From A7 run a yellow wire inj #4
From A15 run a bllc/yel into engine bay
From each inj run the blk/red wire to the resistor box (sequence doesn't matter)
Spark​
At C1 there will be an orange wire, de-pin it and move it to B10
At C2 there will be a white wire, de-pin it and move it to B12
Using the pins from the extra ECU connector (from the supplies list), do the following:
From the now empty C1, run a blue/been wire into the engine bay
From the now empty C2 run a blue/yellow wire into the engine bay
Now you need to cut off the old square DPFI dizzy plug from your engine harness and solder on the round MPFI one. Just match colors from the engine harness to the plug. Yes there are 2 white wires, one is bigger than the other, just match them up.
Now you are looking at the plug and wondering why there are 2 left over wires. The wires you ran into the engine bay from Cl and C2 just so happen to be the same colors, if you used factory colors. If not, the blue/green wire on the plug goes the the wire you ran from C1 and the blue/yellow one goes to the wire from C2.
TPS and EACV​
You are going to need to extend the 3 wires for the TPS about 6 inches, while doing this you need to reverse the 2 outer wires on the connector. You are going to need to extend the 2 wires for the EACV about 8 inches.
Based on the year of your car you will have 2 or 3 leftover plugs, just let them hang there or cut them off and tape up the ends.
I highly recommend that you SOLDER ALL CONNECTIONS and use heat shrink and electrical tape. How you route your new wiring is up to you, but if you left the ample wire when running new wires you should have no problem making it look stock.
I tried to write this as simple as possible. Many people like to use existing wiring but, in my eyes it adds confusion.
Additional pinout information available in our reference section:
Before I did my conversion, I had a real hard time looking online for the right way to do the conversion including what parts I need and what steps. It was pretty much pointless to keep looking online. A friend of mine sent me to a link and im going to share it with everyone cuz I know it was a bitch looking for help. This is for the people who where in my shoes before the conversion (STUCK) so here you go. Hope it helps.
DX,STD (DPFI) -> Si,HX (MPFI) wiring
PARTS/TOOLS NEEDED:(Prices are in canadian currency and may vary depending on where you go)
- Si ECU(PM6 for manual transmission)-----$75-$120
- Si Distributor--------------------------------$50-$120
- MPFI intake manifold - including throttle body, fuel rail, injectors----$70-$90
- Resistor Box(88-91 Si)------$20-$40
- Si wiring harness(needed for injector plugs, injector resistor box plug, and distributor plug)-----$0-$10
- Intake manifold gasket- (not needed but recommended)-----$15-$20
- Manifold Support Bracket ------$0-$10
- Si fuel line from filter to fuel rail-----$0-$5
- some extra wire ------$3-$7
- electrical tape or heat shrink(better)------$1-$10
- wire stripper/cutter------$5-$15
- soldering gun and solder(not needed but highly recommended)------$10-$18
Parts could cost anywhere between $230-$405 depending on what kinds of deals you can find and where you get them from, it may also be cheaper if you buy everything from one person all at once
MPFI manifold on left, DPFI manifold on right.
It is much easier to use your existing DPFI harness and just add the extra 4 wires that will be needed. The Si harness will be much harder to use.
There are two major wiring changes that you'll have to do going from a DPFI system to an MPFI and a couple other minor things that need to be done too. The first one is the crank angle sensor wiring which is the easy part. The second one is the fuel injector wiring which is slightly more complicated. Also, you'll have to switch the two wires on the TPS because the TPS on the new intake works in the opposite direction. If you dont switch them, the ECU will think that the engine is at Wide open throttle when its actually at idle. I highly recommend soldering and heat shrinking any electrical connections you will be making because it is very possible for connectors to come loose from all the vibration and solder will hold up better in the long run. Also, the TPS and EACV plugs are too short and they'll have to be extended. You're also going to have to switch the manifold support bracket, since the bolt pattern from the support to manifold is different from DX to SI, although they still bolt up on the block the same.
TO HOOK UP THE MULTI-POINT CRANK ANGLE SENSOR:
- First, you'll have to go to the passengers foot well to where the ecu is located.
- Pin B10 and B12 should both be empty.
- You'll have to cut and move the wire that goes to pin C1(orange) over to pin B10, and move the wire from pin C2(white) over to pin B12. Don't get these two mixed up or else the ignition timing will be severely retarded. Leave enough wire at the ECU side of pin C1 and C2 for next step.
- Now run wires from pins C1 and C2 into the engine compartment and label them.
- There will be a connector on the new Si distributor with two unused pins. One of the wires will be blue/green stripe, and the other will be blue/yellow stripe.
- The wire that is blue/green stripe will go to the wire from pin C1 on the ECU and the other wire that is blue/yellow stripe will go to the wire from pin C2.
dxsidiagram3sa4-jpg.12266
SWITCHING THE WIRES AT THE TPS:
This pretty much explains itself, just switch the two outside wires(green/white and yellow/white) around at the TPS and then you're done this step. I used the TPS connector off the Si harness, just so that I could just match up all the wires, since the wires are already reversed on it.
INJECTOR WIRING
(In the car):
First of all, while you're still in the passengers footwell, cut wires A3(yellow) and A7(red), although leave some wire on the ECU side for later use. Now run wires from pins A3 and A7 into the engine compartment and label them.
(Engine Compartment):
- Mount the injector resistor box up on the drivers side shock tower.
- Connect the yellow/black wires from the two DPFI injector harnesses and run it to the yellow/black wire on the injector resistor box.
- Connect the yellow wire from the DX injector to the #1 injector (brown wire).
- Connect the red wire from the DX injector and run it to the #3 injector (blue wire).
- Connect the wire you labelled A3 to the #2 injector (red wire).
- Connect the wire labelled A7 to the #4 injector (yellow wire).
- Then, connect the 4 red/black wires coming from injector resistor box to each of the four injectors.
Completed Wiring Diagram
dxsidiagram1xi9-jpg.12267
Distributor wiring completed
dxsidiagram2tw8-png.12268
You should have three extra plugs left over after you are done the swap. two of them are the old DPFI injector plugs, and the other one is for the tandem valve for the DPFI system, which you do not use on the MPFI system, you can either just cut it off, or tuck it away somewhere.
dxsileftoverplugsop6-jpg.12269
OBD1 ECU PINOUT
The # go up and down from left to right.(see)
obd1ecuplugsbb4-gif.12270
Another thing make sure you have extra pin inputs since you will cutting the wire and not taking the complete wire out of its socket.
HOPE ALL OF THIS HELPED SOMEONE.
attaching images for future readiness.
