Hi Guys,
I will be swapping a B18b (from an 01 Integra) into a '94 Del Sol next week. I need some advice/instructions. I need to know what I have to do as far as ECU and wiring. The B18 comes with the original wire harness and the OBD 2 ECU. But I don't think it's no good to use them, right? If I understand correctly, I need to get a OBD 1 B18b ECU (P75) and use the engine harness from my Del Sol, correct? This might sound silly, but will all the connectors from the Del Sol just simply plug-into the B18? What other wiring do I need to change on the ECU side? Also, if you know a good write-up on what I'm trying to do, please give me the link. Thank you for your time.
