0bd1 ecu,harness,engine, vtec help...
goldrims
ok guy, i have a 94 teg obd1 non vtec, iam dropping a 95 jdm h22a obd1 vtec engine in it, i already have a obd1 p28 ecu, a obd1 gsr (obviously vtec harness).. my question is, iam not quiet clear on if i still have to run vtec wires to the ecu manualy, just like i would do if i were to use my stock b18b non vtec harness, can some one clearify this for me, and if so, can someone give me a quick explanation on what i need to do.. thanks guys...
as far as i know you should be able to use the stock harness but will have to run the vtec wires from ecu to motor witch is very simple two wires and then a ground but im not sure about all the sensors hooking up or being the same i have done many swaps but not a h22 hope the info helps
