1990 Accord spark pblms
Discussion in 'Accord' started by Ol phart, Oct 18, 2006.
  1. Ol phart
    Ol phart New Member
    Hope someone can help? Situation is 1990 Accord with no spark.
    Can anyone tell me what is the most likely cause?
    Also I downloaded a CB1, CB3, CB7 (86-91) manual off of the internet, however the ECU pinouts in it show Axx Bxx & Dxx and that there is no Cxx, however it doesn't match with my ECU for the number of pins for each designation. Any idea where I can find something more accurate?
    I would sincerely appreciate any help that can be given.
    Thanks
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    bad distrubtor or timeing belt
  3. Ol phart
    Ol phart New Member
    Thanks for the info. It's not the timing belt as the rotor still goes around and I've bin told that it is an indicator the the timing belt is still intact.
    Yes, I had thought of the distributor but was thinking more to it's internal parts as to what was the most likely to go? Ignitor, coil or TDC/Crank/Cyl sensors
    As I haven't yet found a proper pinout for the ECU, I haven't been able to check the TDC/Crank/Cyl sensors for correct operation. Can you help in this area?
    Thanks
  4. AHHVTEC
    Alabama
    the tdc sensor singnal is pin out B-14 and the tdc input is B-13
  5. Ol phart
    Ol phart New Member
    ahhvtec wrote "the tdc sensor singnal is pin out B-14 and the tdc input is B-13"
    Many thanks for the info. I found my problem, it was the built in ignition coil. Eventho the resistance measurements were what was in the manual, it still didn't give me any spark when I tried it on the bench. (I know, shoulda tried this first) 20/20 hindsight is sure clear!
    I must say I learned a few things about the ignition system with this problem.
    Anyway, thanks again.
