1990 integra gs
Discussion in 'Integra' started by rich55, Apr 9, 2009.
  1. rich55
    rich55 New Member
    i just put a b18b1 into my integra gs and im not gettin any spark or power to my fuel pump? any ideas?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    main relay
  3. rich55
    rich55 New Member
    the one under the dash on the drivers side
  4. AHHVTEC
    Alabama
  5. rich55
    rich55 New Member
    replaced it is there another?
  6. AHHVTEC
    Alabama
  7. rich55
    rich55 New Member
    no replaced it to... unless its bad, but i got two others ill try...
  8. AHHVTEC
    Alabama
    does the motor turn over
  9. rich55
    rich55 New Member
    ya it turns, if i apply power to my fuel pump it comes on
  10. goldgreen90ef
    goldgreen90ef goldgeen90ef
    cold ohio
  11. rich55
    rich55 New Member
    all grounds are good
  12. rich55
    rich55 New Member
    should i just replace all the relays again?
  13. vroooom
    vroooom New Member
    the rotor in the distributor might be bad or maybe the distributor itself. been there with the samee shitt
  14. brian11to1
    brian11to1 Senior Member
    Bad distributor/rotor will not prevent the fuel pump from coming on.
  15. RauL8604
    RauL8604 New Member
    Warren, OH
    shouldve just bout a 3rd gen integra...
  16. BrutalB83
    Rochester Hills, MI
    Should have not commented if you don't have anything useful to add...
  17. hondavet1218
    hondavet1218 New Member
    Yakima Washington
    yes chech your grounds i had this same problem check the wires that bolt to the thermostat housing
