IL 1992 Honda Civic CX, LS Swapped, tons o goodies!
Discussion in 'Vehicles: For Sale/Trade/Wanted' started by Dasfinc, Jul 24, 2008.
  1. Dasfinc
    Dasfinc New Member
    Details: 110K miles on the body, 77K on the motor.
    Car is a 1992 white Civic CX with Blue interior, It has a 1996 B18B1 swap, Plug and play swap (only wires clipped anywhere on the car I re-connected and that was on the Strut-tower brace from my old SOHC Mini-me setup)
    Car is running a OBD1 PR4 ECU, and runs STRONG.
    Car has only had this motor for the past 3000 miles, and had one trip to the track (was towed there and back) where it ran a 15.6 @ 86 with a 2.3 60 foot with me letting off early (Got an 89mph trap later that day, but only got a 15.7). I'm sure the car could break into the 14's with new rear struts, and probably some better tires
    Transmission shifts PERFECTLY, motor runs Damn near flawlessly, and it has a TON o work into it:
    Car has:
    1996 B18B1 motor
    1996 LS Trans
    Black with blue speckle Delsol seats (Seats are flawless)
    GSR Shift knob
    LX MANUAL gauge cluster with 6500 redline tach (I retained the origional Speedo to maintain the miles)
    Hyper-White headlights
    Amber corners
    B+M Short Shifter
    Poly shifter bushings
    New Radiator
    New upper control arms
    new Upper Ball joints
    new front brakes (Pads/rotors/calipers)
    new lower ball joints
    new outer tie rod ends
    new spark plugs
    new spark plug wires
    new fuel filter, both in tank, and under hood
    2.25 Test pipe, and Cat-back into a Cherry Bomb Turbo muffler (Regular oval muffler, painted flat black)
    Intake
    newer battery
    255lph Walbro Fuel Pump
    AEM UEGO Wide-Band O2 sensor and gauge mounted in single gauge pod on A-pillar
    B+M Fuel Pressure regulator
    old-school Solid HASPORT motor mounts
    16 inch rims (I haven't identified them yet, I've been told they may be 'sparkle' rims due to their age.) on a fairly worn set of P205/40/16 tires.
    the bad:
    Ugly, City car so could use some TLC (New drivers fender, hood, paint job, rear bumper)
    Fuel pressure isn't reading right, Car runs fine, I suspect the gauge is bad
    IACV is dirty (occasional idle 'lope' at stoplights, again, will probably deal with this soon)
    Price is $2500 Located in Northern IL. (Ottawa IL, 61350)
    My name is Dan, my number is 630-857-6625
    http://s26.photobucket.com/alb...5.jpg
    http://s26.photobucket.com/alb...6.jpg
    http://s26.photobucket.com/alb...7.jpg
    http://s26.photobucket.com/alb...8.jpg
    http://s26.photobucket.com/alb...9.jpg
    http://s26.photobucket.com/alb...2.jpg
    http://s26.photobucket.com/alb...3.jpg
    http://s26.photobucket.com/alb...4.jpg
    http://s26.photobucket.com/alb...0.jpg
    CAR IS A 2 OWNER CAR!!!
    Was purchased BRAND NEW in 1992 by my father, and it was given to me in 2006, noone else has TOUCHED this car but me and my dad
  2. Dasfinc
    Dasfinc New Member
    Bump for big old price drop, Needs to go! :(
  3. Dasfinc
    Dasfinc New Member
    holy crap cheap price drop bump!
  4. stevennn09
    stevennn09 Member
    Ohio
  5. Dasfinc
    Dasfinc New Member
    $2500.
    it was listed at $3500, I edited the top post.
  6. Dasfinc
    Dasfinc New Member
    Back to the top!
  7. Kirbside
    Kirbside New Member
    Okay, I'm interested. I'm moving to Minn on the 11th of August from Indiana.
    Where exactly are you?
  8. Kirbside
    Kirbside New Member
    Nevermind, just found it (Ottawa). Now I just have to run it by the wife, and you might have a sale!
    I have a 1993 b18c, and a 1997 Volkswagen Jetta Jazz. The Jetta doesn't get better mileage than the Honda, so might as well have 2, right?
  9. Dasfinc
    Dasfinc New Member
    Yea, all the people who I know that have VW's complain they don't get crap for MPG if they are gas powered.
    The car was daily driven until I bought my Fiance her own truck, and it was getting 28mpg mixed, and 30+ on the freeway.
  10. Kirbside
    Kirbside New Member
    Yeah, mine is getting about the same. Long distance interstate trips @85mph yield 33.5mpg.
  11. Dasfinc
    Dasfinc New Member
    Just uploaded new pics, and a ton more close-ups etc.
    LMK, I can't believe this hasn't already sold!
