you're in for a good wiring nightmare.
a) in most states, it is illegal to put an older motor in a new chassis. check your local laws.
b) the motor is obd 0, the car is obd1. you will either need to conver the car to obd0 (illegal) or convert the motor to obd 1 (expensive).
c) the mounts are wrong, and so is the tranny.
You're honestly best off just getting a b18b1 from a 94-95. It will pretty much just bolt right in and wire right up, as you're going to need to source 90% of your parts from this motor anyway to make the mounts/obd/etc all work in your chassis.
