1995 Ghettro no 56k
Discussion in 'Auto Multi-Media' started by Z6CRX, Mar 13, 2008.
  1. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    I've been off and on here for a little while and I haven't posted anything in a while. I came across this for $200 and decided to chance it since I was in need of something fuel efficient.
    1995 1.0L 3 Cylinder probably 40-50ish horsepower 5 speed Geo Metro.
    All it really needs is a new exhaust and rear tires in the near future.
    Think I got a deal for $200? Any recommendations?
    Where the exhaust fell off
    its roomy
    hell yeah scooby doo floor mats sold this car for sure
    power nothing
    Dual Airbags
    hood popper
    If you look closely I think thats the remains of a street sign in the grille.
    No AC no power steering, only an alternator and water pump?
  2. hosmer
    B R I D G E W A T E R
    Metro or Firefly?
    also, its a 94....95's had flush headlights and 1.3's
  3. Celerity
    Celerity Well-Known Member
    Sell it to me so I can put a 1200cc bike engine in it.
  4. daveholiday
    daveholiday Do work
    Pittsburgh, Pennsylvania
    For $200? I'd sure as hell rock it. I bet it gets killer gas mileage, especially with the wind behind it :)
  5. Celerity
    Put a nosecone on it.
  6. |Chaz|
    |Chaz| Well-Known Member VIP
    You should do like that one guy did to that 5th gen Civic, make it super streamlined and get like 150+ mpg.
  7. NissanNiNjA2nd
    NissanNiNjA2nd Senior Member
    First, the brake fluid looks black... so assuming this to be the stock fluid I have to guess that the rest of the fluid is probably stock as well...
    Trans flush, coolant flush, brake flush.... might need newer brakes as well.
    There are several ways to get better mileage out of that motor considering how terribly it was engineered... basically start with the small stuff, filter, tune-up, exhaust... and you can move to head and header later.
    I have a friend that gets consistent 70s out of his.
    Run good gas in it and itll basically last forever.
    1 person likes this.
  8. NissanNiNjA2nd
    Oh... TIMING BELT NOW!!!
  9. INJEN78
    INJEN78 HS LEGEND
    OHIO
    pontiac and geo are the same?!?!?!
  10. invisibledemon
    Tn
    both made my GM my friend.
  11. NissanNiNjA2nd
    Pontiac Firefly = Geo Metro = Suzuki Swift = Chevy Sprint
    I think there is also a Dihatsu or Kia that shares the platform....
  12. 99sidude
    Ohio
    One of my friends had one in high school. It consistently got 60 mpg's. It was actually fun to drive around town because it's so small and nimble. Just don't get hit in it.
  13. Z6CRX
    Pittsburgh, PA
    It's a 95, VIN pulls it as a 95 Geo Metro and stuff matches up. Either that hatch is from a Firefly or its just random badging someone threw on.
    Something interesting, as I took it around the headlight relay, I'm guessing died out. I didn't immediately notice since the fog lights are wired to the parking lights and are pretty bright. Story short, cop pulled me over and let me out of it. But the lights will work if I pull back on he lever that is meant for flashing your lights possibly. Whatever it is it's probably the relay and I'll check it out.
    Also the brake fluid looks good, just looks bad from the shadow and sunlight, the brake fluid in my crx was clear but appeared the same way when you look at the master cylinder. I'll be checking out the timing belt to see how worn it looks.
    Transmission shifts smoothly, but the weird thing is if I'm going over 12 or so miles an hour I cannot shift into second or first from and higher gear. It's like theres a lockout on it. Moment I go below it goes in just fine.
    According to the guy I bought it from it's supposedly leaking oil. I haven't found out where exactly but it hasn't gone down. So I'll be flipping/replacing the PCV valve if it hasn't been done already. Then cleaning out the EGR since those seem to be a common cause of problems. After that cleaning the injectors.
  14. Z6CRX
    Pittsburgh, PA
    Well I could just get a street cone and duct tape it to the front end.
    Anyone know any good info on swaps for a B series in it :ph34r:.
    Probably just going to leave it as is, but I have heard and seen it done, just wondering how much has to be custom fab. Probably mounts linkage(its already a rod type at least im pretty sure) and axles, and of course ECU wiring.
  15. NissanNiNjA2nd
    Remove the entire EGR system and gain 5mpg
  16. TurboMirage
    tranny lockout is not uncommon. my 5g wont go into 1st under 15mph.
  17. Z6CRX
    Pittsburgh, PA
    Yes, but 2nd gear at 11ish. Ridiculous, If I'm going uphill or even on flat ground 3rd gear at that speed the car will not accelerate. Anyway to remove that? It's like driving a fudged up automatic.
    As for the EGR system wouldn't that help my mileage by recirculating unburnt fuel and gasses. Shouldn't the ECU react by adding more fuel, thus making it less fuel efficient?
  18. NissanNiNjA2nd
    that has to do with the trans... the gears are about to eat it
    the egr.. no.
  19. Celerity
    Diahatsu originated the design, in the Charade. The actual "Charade" however, is smaller and lighter.
    Charade:Jimny::Swift:Samurai. They are similar platforms, but the smaller ones are officially called "AUVs" (Asian market budget cars)
  20. killercannible
    killercannible Senior Member
