1995 honda accord ex jdm h22a head work carbon
kingmarc63
need to sell soon. it is a 95 coupe with a jdm 95 obd1 h22a. Made 197 hp to the wheels went tuned.Bear with me through the list of mods this is all off hand im sure i will remember more later.
engine:
block has less than 50k miles
head has about 15,000 miles Gude port polished valvejob
arp head studs
gude street strip cams
gude ported intake manifold with secondary runners open
AN-R.com 70-66 throttle body
str fuel rail
kms egr block off
skunk2 cam gears
milled head
new head gasket
jdm blue valve cover with moon cut around cam gears and matching belt cover new obd1 internal coil distributor
nology hotwires and platinum plugs
p72 gsr ecu by inline pro with no egr (no check engine light)
vafc2 black screen tuned with aem wideband
AN-R.com equal length headers 2 1/2 collector
custom 2 1/2 exhaust catco cat magnaflow muffler
prelude axles and midshaft (much stronger)
energy front motor mount insert and prelude drivers side mount (new)
fidanza 8lbs flywheel
clutchmasters stage 3 clutch
removed balance shaft belt
new timing belt water pump
lightened crank pulley
no ac
power steering works
CAR:
skunk2 2 1/2 springs
gr2 shocks
some polyurethane bushings
suspensions techniques front and rear sway bars
front rear strut bars
brembo blanks
spc adjustable balljoints camber kit (best on the market)
adr 17 inch concept pros gunmetal with polished lip
kumho 711 tires 90% and 75 %
35% window tint
VIS carbon hood and trunk....hood is messed up on the side.trunk is perfect
new black fenders due to some waves in the white ones.
new jdm headlights and corners
chopped shifter
gsr boot
panasonic touchscreen head unit
rockford front polk audio rear speakers
removed back seat but will include. currently carpeted and clean look
blue black racing seats sliders and brackets
new abs unit
new iac valve
new clutch brake master cylinders
body is in above average condition.
http://pg.photos.yahoo.com/ph/marcayla2002/album?.dir=/848d
ASKING $5800 :worthy:
engine:
arp head studs
str fuel rail
kms egr block off
skunk2 cam gears
milled head
new head gasket
no ac
CAR:
gr2 shocks
brembo blanks
35% window tint
chopped shifter
gsr boot
new abs unit
new iac valve
I will be getting some outdoor pics soon. It was raining when i took these
[post=533297]Quoted post[/post]​
nothing wrong with it. One fender was vandalized and i changed both to black unpainted ones. I haven't tracked it because its my family ride (wife drives it mostly). Should do low 14s wih a good driver and smaller wheels.
Originally posted by SPEEDFREAK0920@Jul 30 2005, 08:19 PM
sick cord man.is anything wrong with it ?have you tracked it ? thnx
[post=533441]Quoted post[/post]​
show love to da h22a accords
SPEEDFREAK0920
[post=533444]Quoted post[/post]​
bump
:worthy:
SPEEDFREAK0920
[post=536221]Quoted post[/post]​
bump :worthy:
Originally posted by kingmarc63+Aug 12 2005, 09:39 AM-->
bump
:worthy:
SPEEDFREAK0920
[post=539208]Quoted post[/post]​
