1996 civic ex front clip swap
Discussion in 'Body / Exterior / Interior / Cosmetics' started by matt13320, Aug 6, 2013.
  1. matt13320
    matt13320 New Member
    I have recently totalled out the front end of my 96 civic would I be able to use a 94 civic ex front clip? If so what modifications would be required?
  2. Matts96HB
    Matts96HB . Moderator VIP
    I suppose anything is possible with the right fabrication skills, but I have to say in this case it is simply not worth your time to try and fit that clip to that car.
  3. matt13320
    Are they that far off bolt pattern wise?
  4. Matts96HB
    I can't say for sure because I've never done it but just by looking at the geometry of the front ends there are some major differences that I can see. I think you'll have issues getting the fenders to fit right, the hood to line up with the fenders, etc. But again, never done it so I can't say 100% for sure.
  5. matt13320
    would an engine swap be easier both cars use the exact same engine and tranny
  6. Matts96HB
    :yes: I'd do that instead. What are the specs on both cars? Both have running engines or just one?
  7. matt13320
    the 96 has the engine the 94 is just a shell the 94 had a b18 swap but the guy sold the engine and tranny when he got his 02 si all the mounts and stuff are intact from my car and they both used the same radiator so i think i might have to do that
  8. Matts96HB
    Yeah you can swap it all over.. the wiring might get a bit tricky. Maybe get a stock 94 ex harness and a chipped obd1 ecu and then throw a map for the new engine on it.
  9. awptickes
    MD
    Just remember that you can't legally swap a 94 engine into a 96 chassis.
