1st time i heard this (no one can help or what?)
Discussion in 'Engine Building' started by 4DRonDUBS, Oct 16, 2004.
  1. 4DRonDUBS
    4DRonDUBS Senior Member
    I have been throughing a cel for a long time and i just heard that on my mini me set up you need your timing belt tooth, 1 tooth off so the tdc sensor doesn't throw a CEL is this true and what way is the tooth off towards the cab of the car or towards the bumper.? In every write up ive read ive only heard this once heard I could use some help my car throws this #8 tdc CEL every so often.
  2. dahondayguy
    dahondayguy Junior Member
    whut r u trying to get across?
  3. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    TDC sensor is in the distributor...you could have your cams 180'd out and still not throw TDC...your distributor is bad...something mechanical will not get rid of any problem that is electrical.
