2000 civc w/ b18
Discussion in 'HYBRID -> EG-EK / DC' started by greg@millennium, Nov 12, 2007.
  1. greg@millennium
    greg@millennium New Member
    swap help: 2000 civc w/ b18
    have a 2000 civic ex w/ a blown engine. sitting next to it is a b18c1 engine & trans (hyd), axles & ecu. was wondering about what else (harness, mounts, etc) would be required to complete the swap.
    thx
    greg
  2. Matts96HB
    Matts96HB . Moderator VIP
    EDIT: shit, i thought you said civic Si.
    My bad. For a b-series swap, you will need:
    Shift Linkage
    Upper Tranny mount
    Driver side upper mount
    torque mounts
    ecu
    and you will need to run wires for vtec solenoid/knock sensor
    if the b18c1 is obd2, youre fine
    if its obd1 u need ajumper harness
  3. greg@millennium
    yea its a d series engine in the car now. the b series in sitting next to it. were do i get the jumper harness?? the ecu has 94-95 written on it. were do i find the diagram for the vtec & knock sensor wiring??
    thanks
    greg
