$250 O2?
you can get four wire universals from your local autozone. the only draw back is that you have to wire in your plug. this is a good time to add an air/fuel meter because you want to soder the connectons so you dont get interferance from your ignition. they go for about 60 bucks.
" you can get four wire universals from your local autozone. the only draw back is that you have to wire in your plug. this is a good time to add an air/fuel meter because you want to soder the connectons so you dont get interferance from your ignition. they go for about 60 bucks. "
what if i put my a/f gauge and didnt get it sodered?? will that cause me to get a code 41 "o2 heated sensor malf." cause thats what im gettting now.
:werd:
