REVLIMITSOLJAH
i was wondering what i would have to change as far as the wiring harness went. Im swapping a 2000 b16a2 into a 2000 lx 4dr. I dont think there is a connector for the v-tec solenoid, i think i may have to pin it out. Was wondering if for the most part i could use the stock harness and not have to buy 1. I was just gonna use all trans stuff from a 2k si. Also i was wondering if the a/c compressor and bracket can be used. What t-bracket i would need? Also wondering if i could use the same p/s pump and bracket. Can i use the same trans torque mount? Otherwise i hope this swap is pretty straight forward, any insight would be appreciated, thanks.
