4 wire o2 sensor
Discussion in 'ECU's, Electronics, and Tuning' started by pork1463, Sep 25, 2003.
  1. pork1463
    pork1463 Junior Member
    elgin, IL
    Ihave a 92 cx hatch. I just put in a b16a2 and my old harness worked for everything but the v tech and the o2 sensor. I got the v tech working but i can't figure out how to wire the o2 sensor...My old o2 used one wire now this one has 4..Can anyone help? thanks
    Mel :blink:
  2. Bl6CRX
    Bl6CRX Senior Member
    UCLA
    hmmm, not to sure about that one, cause since your car is a 92, it should be obd1 which has a 4 wire 02 sensor, i would expect that out of an obd0 car (91 or before) because they have one wire 02 sensors...don't worry though cause your harness can be converted to use the 4 wire because mine is so i can run obd1
  3. radnulb
    radnulb Senior Member
    Sinsinnaty, Ohio
    CX came with one wire O2 sensor.
    You need to run a couple additional wires.
    4wires on O2:
    White=
    Black=
    Black=
    Blue=
    You need to run A6 on the ECU (O2 Heater) to one of the black wires.
    The other black wire needs to get tapped into a switched 12V signal somewhere in your harness. do NOT wire it directly to the battery - tap another signal that gets turned on with the key. Most black/yellow wires on the engine harness are +12v switched.
    The blue wire needs to be run to ground.
    The white wire needs to be run to the original CX O2 sensor wire.
    That was from memory, so I might be dyslexic on the colors. Someone else should verify before you go cutting and splicing.
  4. pork1463
    elgin, IL
    Thanks I'm going to go look at it. I'll get back. :worthy:
  5. rudeludenotmeanthough
    rudeludenotmeanthough Senior Member
    when the key is in the ON position not the acc.
