5 point harness mounting
Discussion in 'Civic and CRX - EF' started by goldwar, Nov 17, 2007.
  1. goldwar
    goldwar New Member
    ok well this is a noob question but i just bought courbeau 3" camlock harnesses and i cant figure out the where i'm sposed to to mount them on the frame. cant seem to find any pics or posts or anything on the subject anything would be helpful thanks.......
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    well to mount it correct your gona need a seat belt bar, for the shoulder belts, if the shoulder belts are mounted to the floor or something like that if you get in a wreck, if will crush your spine,the shoulder belts need to be level or just slightly lower than your shoulders
  3. goldwar
    goldwar New Member
    well im going to run them back to my strut bar but i was wondering where the other 3 should be best mounted at.....? fyi this just a track car not my daily driver
    89
    crx si
    gutted
  4. AHHVTEC
    Alabama
    even on the track they need to be mounted high the shoulder belts that is a wreck is a wreck,but the others will be ok mounting them to your seat bolts
  5. goldwar
    goldwar New Member
    i'm sorry the little bolts that hold down the seat braket
  6. AHHVTEC
    Alabama
    yea the bolts on the back of the seat rails thats hold the seat and all down
  7. MXDesa
    MXDesa Senior Member
    Queens, New York
    Correctly?? Go to Jegs.com and order harness anchors that come with eye bolts and the proper hardware.
  8. norcalgsr
    NorCal
    That's how to do it.. no other way is acceptable.
