6 speed EG?
Discussion in 'HYBRID -> EG-EK / DC' started by SuperZaque, Oct 24, 2002.
  1. SuperZaque
    SuperZaque Junior Member
    I'm looking to put a b18c1 into a 94 civic CX. can anyone tell me if I could stuff a 6 speed from a new rsx into this combo - how much would it cost?
  2. [Jett]-CRX
    [Jett]-CRX Member
    Maumelle, AR
    Hrmm... I don't think the tranny from a K-series engine will bolt up to a B-series.
    Sorry bud.
  3. E_SolSi
    Apexi is the only company i have seen or even heard of running a B series engine with a 6 speed tranny .... the problem is honda motors ( up untill the RSX and new civics ) all spin in the opposite direction of every other engine on the planet ( i have no clue why ) so basicly even if you could get one of the aftermarket trannys to mount up to the engine ... youd have 6 speeds in reverse ( not too usefull ) Apexi got it to work though ... they redid the engine so it would spin in reverse then mounted it backwards in the engine bay ( headder near the firewall ) .... so i would say yes it can be done... the ammount of money required to do it is absolutly retarded though and will not come anywhere near making it a worthwile thing to do
  4. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    i thought quaiffe made a six speed sequential or something...
  5. chris
    chris Senior Member
    nihon
    u can slap a 6 speed from a k20 on an f20c now, someone makes the kit. good luck getting that into an eg tho <_<
  6. E_SolSi
  7. SixtySecondAssassin
    Austin, TX
    the f20c is in the s2000 which is already a 6 speed, ace.
  8. phunky.buddha
    Dallas / Fort Worth, TX
    Yes, but the F20C uses a RWD transmission where the K20A2 uses a FWD 6 speed transmission.
  9. SixtySecondAssassin
    Austin, TX
    true. so what would be the purpose of the kit? to put the f20 in a civic?
  10. phunky.buddha
    I guess so. I'd rather build up the stock K20.
  11. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Yes Quaiffe makes a six speend sequential, it will cost you $$$ and you soul. Seriously though, they are really expensive. You are better off just leaving it a 5 speend.
  12. chris
    chris Senior Member
    nihon
    yes i am aware of that sir, the purpose is to put the rwd f20c into a ff dc5...
  13. SixtySecondAssassin
    Austin, TX
    they sell this kit commercially? the mounts on the f20 would be on the wrong sides of the engine. has anyone ever done this?
  14. lsvtec
    I have never heard of it, but I imagine that someone somewhere has tried it.
  15. chris
    chris Senior Member
    nihon
    yes they do, i will try to dig up the site later. i am not promoting this swap nor even agreeing with it, just saying it is out there. they look, handle, repsond a whole lot better in a rwd corolla than a ff dc
  16. pissedoffsol
    All said and done, WHAT IS THE POINT OF A 6 SPEED????
    I mean come on- unless you want to do 1212233 mph, or feel like shifting every 10 feet like a rig, you really don't need it.
    If you want more acceleration that more gears would add- run a b16 or itr tranny matted with a 5th gear from the ls.
    you want to go 1000 mph, run an ls tranny, and get a cusomt FDR that is liek 2.234:1
    it can be done with 5 speeds
    it can be done with 4
    shit, some old ass drag muscle cars are on 2 speeds.
  17. phunky.buddha
    Actually, I wouldn't mind a 6th gear on mine... it accelerates really nicely in 5th, and it's extremely useful from 115-150... but I really wouldn't mind a cruising gear.
  18. lsvtec
    Get an LS 5th gear for your tranny. It should still pull (I have driven a well built LSVTEC mated to a B16 tranny and an LS 5th gear).
  19. phunky.buddha
    Nah, I'm not going to pull the tranny again unless I absolutely have to. I'm fine on the 5th gear- I like it short like it is now. I just need a 6th.
    :D
  20. pissedoffsol
    again- its just a matter of fuel economy - thats what 5th gear is made for... manual eqiv of sorts to lockup
