85 dx to d15b
Discussion in 'Civic and CRX - EW' started by crxhfz6, Nov 18, 2009.
  1. crxhfz6
    crxhfz6 Member
    Manhattan, KS
    the motor in the car now is having some problems so i was looking at getting a carbed d15b. just looking for a daily driver. I heard that a the transmission mount for the integra would have to be used but the others would work. also what axles and shift linkage or will what i have work. thanks
  2. h22a91civichatchswap
    h22a91civichatchswap New Member
    Cedar Rapids, Iowa
    i thought that the d15b's were all fuel injected between the duel port injection and the multi port injection?
  3. RoughKnight
    RoughKnight Christmas Car
    Ottawa, Ont
    he might be talking about a b2 or such...
  4. crxhfz6
    crxhfz6 Member
    Manhattan, KS
    well on tiger japanese they have listed a d15b with a dual carb
  5. jlicrx
    jlicrx Senior Member
    Colorado Springs
    in order to use the JDM D15B, you would have to use the 88-91 L3 transmission and fabricate all new mounts for the engine (driver's side mount is completely different) and transmission - the D15B engine will not bolt to the 85 transmission - you would also have a lot of wiring problems
  6. crxhfz6
    crxhfz6 Member
    Manhattan, KS
    i have two spares trans that i have for my 89 in case i ever needed them. what kind of wiring problems. there are not many wires to begin with and im staying carbed with it
  7. 78civic
    78civic Junior Member
    NW MS, Y'all
    What kind of 'problems' are you having with the 'stock' setup on your current car?
    Carb base leaking air? You might do better($$) by doing a webber swap on the dx engine.
    E
  8. crxhfz6
    crxhfz6 Member
    Manhattan, KS
    well yeah the carb was kind of gummed up i think but recently my mom drove it and somehow got a leak in the radiator. the motor got hot enough that it snapped the head bolts for the exhaust. i got it all fixed but it runs funny and im not sure if i trust it.
  9. 91civisedaner
    91civisedaner Senior Citizen
    oregon city or
    Find a decent running 86-89 integra an swap in the motor and trans!!:D:D:D
  10. RoughKnight
    Ottawa, Ont
    So, after a two (yes, 2) second search on Google, you would have found your info. On top of that, everybody on those other sites have the same consenus for your car.
    You will have to get rid of the carb, convert it to obd1 and run a p28. You won't be the first to do the swap, but thats what you need to do.
    Next time, read my sig.
  11. crxhfz6
    crxhfz6 Member
    Manhattan, KS
    but im not looking to get rid of the carb. that way i wont have to mess with a lot of wiring and fuel system work. all im looking for is an easy swap for a reliable dd
  12. 91civisedaner
    oregon city or
    Roughknight,He's talkin' 'bout the d15b NON-VTEC with duel carbs
  13. RoughKnight
    Ottawa, Ont
    ^^ which is not a d15b, it is a d15b2 which is what I said in earlier posts
    either way, he has work cut out for him
  14. jlicrx
    Colorado Springs
    the engine he is wanting to get is in fact the JDM D15B dual carb model, which looks like this:
  15. RoughKnight
    Ottawa, Ont
    ^^now that is one rare fker
    gl with the swap, my knowledge stops here lol
  16. h22a91civichatchswap
    Cedar Rapids, Iowa
    jlicrx were did you find that i couldn't find that anywhere but yeah that engine is a rare one
  17. h22a91civichatchswap
    Cedar Rapids, Iowa
    well obviously i wasn't looking hard enough to find it
  18. 78civic
    NW MS, Y'all
    Jilicrx.. Would those carbs be Kehins (?) like the older ones?
    That made me laugh.. I just spent 2hrs gettting pics off my old floppys and saw my old RS-setup ones from my 1200..
    E
  19. 78civic
    NW MS, Y'all
    I don't think that overheating would break headbolts.. Check the cat. The older carbed engines were electronically controlled and could've clogged it.
    Put some good NGK plugs in it. (cheap) Make sure your wires are on right!!
    check/replace the cap/rotor (cheap) Is there "red dust" all over inside?
    check the vacume advance on the dizzy.. Holding vacume?
    check timing. valve and ignition
    Who told you/her that 'bolts were broken'??
    PM me if you need exhuast studs.
    You could always pop a header on it..
    E
    1 person likes this.
  20. crxhfz6
    crxhfz6 Member
    Manhattan, KS
    i saw that the studs were broken when we got the car home. I had enough to replace all but one of them and i changed out the plugs and it running a lot better. im going to try to work on the carb this weekend to see if that helps
