88 prelude si exhaust
Discussion in 'Prelude' started by sleepercrx90, Aug 15, 2008.
  1. sleepercrx90
    sleepercrx90 New Member
    South Carolina
    i just bought a 88 prelude si with the b20a5, and i love it. i installed a new timing belt, water pump, cam seals, and crank seal, so now its ready for some aftermarket mods.
    its got a short ram intake but the exhaust is stock. i am looking for a fairly loud exhaust sound with a raspy tone. does anyone have any advice on what to do, and what sounds good. should i keep the resonator and cat, or should one or the other go. by the way i just ordered a 4.5" tip muffler, so that will also go on.
    thanks
  2. George777
    George777 ^^ Likes Bewbies
    With your mom
    The Cat and resonator should be left on there for smog/emission reasons.
    Why would you want a loud exhaust? I don't know where you are from, but most often they are just cop magnets, not to mention they get annoying after a while.
  3. sleepercrx90
    South Carolina
    do u even have a prelude, im looking for good advice on exhaust, your not telling my anything i dont already know
  4. MIK99
    MIK99 New Member
    Cleburne, TX
    are you looking for a performance exhaust system, or just the sound? cus you can get the sound by cutting some holes towards the back if thats all you want.... as to a performance system, i dont know
  5. George777
    With your mom
    Whether I have a Prelude or not doesn't make a difference. You don't have to be a Prelude owner to put an exhaust on a car.
    Put whatever you want on the car. "Loud and raspy" may be what you think is cool, but to most others, it's rice. But at 16, I guess you know everything you need to.
    Another noob that will give nothing but attitude to anybody and everybody on this site...
  6. sleepercrx90
    South Carolina
    yeah, i already cut a hole in the piping in front of the muffler, and it gave it some deep sound, but its not quite the sound im after, do u know how taking out the cat or resonator would affect the sound?
  7. sleepercrx90
    South Carolina
    thanks for the advice
  8. MIK99
    MIK99 New Member
    Cleburne, TX
    couldnt tell you, I dont have very much experiance with exhaust. I just know that when my exhaust started to rust through, it sounds awesome..... to me! :D
  9. Slow&Delirious
    Slow&Delirious isn't fast or furious
    Boonville NC
    so you just want an exhaust system so your car will be loud?
    get the Nopi #1 cat back system, its cheap & loud
    btw, you are a ricer.....
  10. Ethan
    Ethan Well-Known Member
  11. BrutalB83
    Rochester Hills, MI
    You cut a hole in your exhaust pipe to make your car loud?
    You = Rice
    Now that that's out of the way, what size is the inlet on the muffler you ordered?
  12. sleepercrx90
    South Carolina
    hey be easy on me, i was bored and didnt have any money.
    anyway, it has a 2.5" inlet
  13. BrutalB83
    Rochester Hills, MI
    Alright then, well what I would do next is, take your muffler to an exhaust shop, and tell them you want a custom exhaust system using the muffler. Usually I'd recommend a 2.25" exhaust for an N/A Honda, but since yours is a 2.0 liter and your muffler has the 2 1/2" inlet, I'd probably just go with 2 1/2" pipe. They may give you a choice between stainless piping and aluminum piping. If you're willing to spend the money on stainless, then go with that. It won't rust out. Tell them you want a full 2 1/2" exhaust from the cat back, and that you don't want any resonators in it. This should give you a smooth-flowing exhaust that's also decently loud and throaty sounding.
    If you can't afford an entire system, then you can just ask for the resonated portion of the exhaust to be removed and replaced with straight pipe. If your state does inspections, then you'll want to keep the cat converter. If they don't, then you can replace it with a test pipe, but you'll have to buy it and install it on your own. The shop probably won't want to mess with the cat converter (unless they're shady and you pay in cash).
    So yeah, in review...
    Best option: Have entire exhaust pipe replaced with straight 2 1/2" pipe from the cat converter back, and finish it off with the muffler.
    Other (not so good but still loud) option: have the factory resonator replaced with straight pipe, and have the muffler welded on to the factory exhaust.
  14. sleepercrx90
    South Carolina
    thanks for all that. i think ill go with the 2.5 inch pipe ran back from the cat to the muffler, with no resonator.
    i might get a test pipe and put it on just to see how it sounds, but it will most likely be way to loud, so ill just leave the cat stock.
  15. BrutalB83
    Rochester Hills, MI
    Sounds like a good plan! :thumbsup:
