Ok Well First You Want To Convert It To Multi-Point You Can Find A Ton Of Write Ups On It, And You Can Even Send It Into Rywire.com And Get It Done, After Its Multi-Point, You Need To Get A Y7 Or Y8 Timing Belt, Then I Would Get A Virgin OBD1 P28 ECU A Conversion Harness For The ECU And The Jumper Harness For The Dizzy, Then You Need To Get A D15B7 Dizzy, And Hook Everything Up And Wire Up Vtec And You Will BeGood To Go, Theres Good Write Ups On All This Stuff
