Need help with b20 swap
so I got a unfinished project car, its a b20 I have mounted the motor into it but the wiring is incomplete the car is a 91 sedan dx and according to the old owner its been swapped to obd1 but is missing thing wiring multiple things including the distributor. I don't there is an easier way of fixing this. also I dont know very much about civics or what they need so if you know of any recourses, please send them. finally if there is any advice or recommendation anything will help at this point
This may be tricky as you have no idea where it was left...
hf/si are multi-port, but the dx is not. you'll need to convert to mpfi and figure out the injectors
the b20 is likely obd2 so if it's been converted to obd1 as well, (dist, ecu + jumper harness, etc)
I think you need to take inventory of what plugs you have (and from what harness) and what the engine requires. It's really hard to see what's going on in the pics.
