'89 DX. overheated d16a6. replace with d15b2 any changes needed?
Discussion in 'Civic and CRX - EF' started by corruptpc, Sep 23, 2009.
  1. corruptpc
    corruptpc New Member
    i bought a 89 civic hatch from a friend. his motor overheated. i guess cuz oh his radiator. bought it for $200. i have an oportunity to buy a d15b2 for $100.
    i was wondering if this motor will swap right in? any changes to the harness? ive been searching... but im new to civics and sohc. i mostly mess with integras and b series. ive read something abot mpfi and dpfi conversions. i hope this isnt necessary in my case. is there anything else i need to buy? new ecu? i think the b16a6 has the pm6, and ive read i need the pm5 or 4. so much info :( dont know whats reliable info.
    someone help.
    bottom line is: i have a chance to buy the d15b2... and replace my busted d16a6... should i just do it? i just want to get this car running. if getting this motor working right in my 89 civic dx will be somewhat easy and inexpensive, ill go for it.:D
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    well the d15b2 motor has a different harness because its dpfi and not mpfi like the si motor.also the ecu is different, but other than that its perty much a direct swap
  3. corruptpc
    so i have an si motor... does that mean the whole car is an si? maybe that motor was swapped in. i dont see any SI decals.
    here is info from wikipedia
    D16A6
    Also known as D16Z2.
    • Found in:
      • 1988-1991 Honda Civic Si, CRX Si, Civic Wagon RT4WD
      • 1990-1991 Honda Civic EX Sedan
      • 1988-1995 Honda Civic Shuttle RT4WD (UK/Europe/Asia/AU/NZ)
      • 1989-1996 Rover 216/416 GSi/Tourer (UK/Europe)
    D15B2
    • Found in:
      • 1988-1991 Honda Civic GL/DX/LX
      • 1988-1991 Honda CRX DX
      • 1992-1995 Honda Civic LSi Hatch/Saloon (European Market)
      • 1990-1995 Honda Concerto (European Market)
    according to the above, my car originally had a d15b2. am i right? so... if my car is a DX... with a d16a6, im assuming that it was swapped in.
    confused. :( anywayssssss. this would also mean that i have an si harness... so BASICALLY... i would just need to get the original parts (motor, ecu, engine harness) and BAM. done, no?
  4. AHHVTEC
    Alabama
    well does your car have a sun roof ?
  5. jlicrx
    jlicrx Senior Member
    Colorado Springs
    take the intake manifold, injectors, etc. along with the distributor from the D16A6 and install them on the D15B2 and drop it in - just like doing a DPFI to MPFI swap, except the wiring is already done
  6. INJEN78
    INJEN78 HS LEGEND
    OHIO
    word..then later on when you wwant to upgrade..its already ready
  7. Magana559
    Magana559 The Warden
    fresno Ca
    b2's are known for faulty head gaskets :ph34r:
  8. GlassHeadlights
    Calgary, AB
    I don't think so, they use the same gasket as the A6. No matter what motor you can expect the headgasket to go out between 300,000-400,000 miles.
    Also here is my 1989 Si hatch with a D15B2 (Si intake manifold). I didn't notice a difference between A6 and B2.
    YouTube - 1989 Si hatch with D15B2
  9. Magana559
    fresno Ca
    dont the b2's have a graphite head gasket?
  10. GlassHeadlights
    Calgary, AB
    I though it was called metal composite. Anyway the A6s have the same gasket. Most '92 and up use a stainless MLS gasket, it lasts longer if you deck(s) are nice and flat.
