89 si hatch dohc zc
Discussion in 'HYBRID -> ED-EF / DA' started by ef9junkie, Jan 22, 2012.
  1. ef9junkie
    ef9junkie New Member
    whats uup guys
    i got an obd0 dohc zc in my 89 si and its throwing up code 9 for the cylinder position sensor
    ive tested all the resistance and everything and even changed the sensor and the dizzy is brand new also
    ive checked over the wiring many times
    does anyone else know why it would be showing that code
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    usually, the code 9 is caused by one of the following:
    1. wires switched at the connector
    2. wires not making a good connection
    3. exhaust camshaft timing not correct
    4. bad cylinder sensor - this would be extremely rare - we have been working with the DOHC ZC for over 10 years and have swapped over 50 of them - we have never seen a bad cylinder sensor - i know that it sometimes happens but we have never seen it
    mostly, we see incorrect camshaft timing or wiring as being the problem
    the cylinder sensor is easy to check to see if it is o.k.
  3. BaDarkus91lsvtec
    BaDarkus91lsvtec New Member
    palmton, ca
    Same problem
    Post if u get rid of that check light and what it was cuz ive had ppl look and they say they can fix it but the world is full of flakes. Thanks for the diagram jlicrx
