90crx dx b18b1 swap
Discussion in 'HYBRID -> ED-EF / DA' started by mackh1017, Sep 25, 2003.
  1. mackh1017
    mackh1017 Junior Member
    ok i am in the process of doing a b18b1 motor swap in my 90 dx model crx. i just got off the phone with a friend of mine in pensacola, fla. he said that that engine wont be any good cause it is an obd-1 engine and i have an obd-0 car. now i know that there are tons of you people out there with swaps in thier crx's but what i need to know from you is if he is right or not. the b18b1 is a non v-tec motor out of a 95 integra rs model. is this an obd-1 engine or what? and if i do drop it in my crx will the fuel and air mix ratios be a bitch to twerk or can i fix all that with a simple ecu swap????
  2. brian11to1
    brian11to1 Senior Member
    it is an OBD1 engine, however you still put in your car, your friend was wrong. You'll need to
    1. switch from OBD-0 to obd-1 or...
    2. get an OBD-0 wire harness for your car.
    I've heard that OBD-1 runs better than OBD-0, tere are companies who make kits for this swap... have you wired for MPFI (multi port fuel injection) yet? Got mounts yet (Hasport)? Shift linkages (Hasport)? You'll need a Hydrolic to Cable, or Cable to Hydrolic conversion kit whatever it is called (Hasport) conversion kit. Hasport, the links I have provded makes all this shit you need, hte links you can make yourself though, there should be a how to article on this though
  3. mackh1017
    ok i have not yet wired up for mpfi nor do i know which ecu i need to get for that. and i have no tranny yet cause the tegra i got this motor from was an auto. i am hoping to get a cable tranny out of a 90-91 tegra. any more pointers out there anyone?????
  4. brian11to1
    SIR Transmission 88-91 are good for 1/4 mile racing, good gearing, and any B series transmission form 90-93 will work, at elast out of a 90-93 Integra that is, and any sir trans from 88-91 will work... b18b1 I blieve is a pr4 or a P75... check teh reference section for more...
