91 Accord Se
Discussion in 'Accord' started by mes, Jul 2, 2010.
  1. mes
    mes New Member
    Got a 91 Accord SE with over 300k on it, wanna do an engine swap, but i wanna build it myself, any suggestion?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    h22a
  3. mes
    mes New Member
    i want something i could build myself
  4. mes
    mes New Member
    plus how would i go about doing a tranny swap ( auto 2 manual)?
  5. BrutalB83
    Rochester Hills, MI
    What kind of answer are you looking for here? An H22A is the perfect swap for your car. It's pretty much a bolt-in swap. If you don't feel like you can work on an H22, then there really aren't any other swaps that I would recommend to you. Honda motors aren't that complicated....
  6. mes
    mes New Member
    i wanna do a swap that i can build from the bottom up, not buy.
  7. AHHVTEC
    Alabama
    same answer h22
  8. Korax
    Korax New Member
    Western PA
    Well technically if you are swapping your gonna have to buy something, unless you plan on stealing everything. I'm not sure how you are trying to get away with a swap and not buy anything. That F22a you got is one of the best motors honda has ever made. Unless you are sticking a K24 in there (hasport does make the kits for it) i would just boost that F. Or hell, call up bisimoto.
  9. BrutalB83
    Rochester Hills, MI
    How do you expect to do a motor swap and build and not spend any money on it? I still don't understand what you're asking for here. If you're just wanting a basic motor to build up, then no need to swap at all. Rebuild your stock engine and put a turbo on it. That should easily get you in the 200+ wheel horsepower range...
  10. mes
    mes New Member
    Ok thank brutal, but what i actually wanted to do was a build from scratch including parts from this engine i got. I wasn't into adding a turbo, i wanted to see if i can get pure power from an engine itself.
