91 civic dx wiring issues
Discussion in 'Civic and CRX - EW' started by mkerley, Mar 13, 2007.
  1. mkerley
    mkerley New Member
    im putting a 89 si single cam motor into a 91 dx. the plugs on the si harness will not match up. what do i need to do? i was going to use the plugs off of the si body harness but i cant find the wiring any where.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    you will need a si or hf motor harness or convert yours to mpfi
  3. fixed4 life
    fixed4 life New Member
    Haltom City TX
    You need to do a MPFI conversion. You need to modify your stock harness using a 88-91 Si (or Hf) harness then you need to splice and move some wires on the ecu plugs under your passenger carpet. This website will give you directions on how to do that.
    MPFI Swap
  4. AHHVTEC
    Alabama
    the hf and si are already mpfi
  5. mkerley
    mkerley New Member
    i have the si harness, but the body plugs will not match up.
