91 crx si
Discussion in 'HYBRID -> ED-EF / DA' started by bjoebright14, Dec 15, 2008.
  1. bjoebright14
    bjoebright14 New Member
    if i wanted to swap motors would a b16a be a good swap?im kinda new at this i know a little though lol
    1 person likes this.
  2. hondacivicguy05
    hondacivicguy05 New Member
    Rome ga
    well it depends on if you know what you are getting into and how much money you are looking to spend on the swap and how much knowledge you know with hondas
  3. hondacivicguy05
    Rome ga
  4. 95b16coupe
    95b16coupe New Member
    ct
    read around the forum for 10 minutes before posting next time. i'm sure you will find your answer.
  5. bjoebright14
    i know a little there are some things im not to sure about and want to learn but i found a jdm for 2000 with 33k on it is that good and some say to replace the axles too along with like shift linkage and things like that but im not sure about the axles do they need to be changed and i use the stock wiring harness with a adapter or something like that right?
  6. hondacivicguy05
    Rome ga
    try rywire for the harness and hasport for linkage and mounts and for the axles i'm not sure about that
  7. bjoebright14
    does it like just plug in the wire part confuses me
  8. hondacivicguy05
    Rome ga
    yes most of it is plug and play and some you have to wire in yourself
  9. cjvictoria
    cjvictoria New Member
    N. Chuck, SC
    a JDM what? I'm wondering because you ask if that's a fair price, but I'm not sure what engine you speak of. and wtf the spell check on here just said iI spelled 'speak' incorrectly! B fix it please
  10. bjoebright14
    thats the part im worried about is wiring myself what would i end up wiring? and jdm is japanese domestic market
  11. cjvictoria
    N. Chuck, SC
    Ok, no shit. Look man I'm asking what the specific engine is; D15, D16, B16, B17, B18, B20, H22, H23, K20, K24 etc. Most likely what you are looking at will fall into one of those engine families. If your trying to put a JDM motor into a CRX, as said in the link a few posts ago, you are severely limited in your choices unless you want to do a shit ton of fab work and spend lots of cash in the process.
    Here is what i know about them.
    D series will go well, as will B series engines. The B series will be a little more work since you've got to either make your own mounts or order some from hasport. The B swap will also require alot of wiring modification. H series engines I hear are not so hard, but they are'nt exactly cheap. K series engines swap will require HUGE amount of labor and money to complete it.
    Do this: Look in the ad where you found the engine. Try and see if there is anything about the engine model listed in the ad.
  12. hondacivicguy05
    Rome ga
    and add us some rep for helping you lol
  13. b16vt3c
    b16vt3c 95 EJ1 d16z6 turbo'd
    woodbridge
    i depends on the knowleage you got on hondas
    and how much money you willing to spend on the swap
    cus i spend 2500$ on a b16a 4 mounths ago on my civic teal eg
    i build most of the block cus it had a hole bout the size of fist
    cus the kid used it 2 race and didnt dupble shift
  14. LILBLKCRXSI
    LILBLKCRXSI New Member
    :wtf2:
  15. bjoebright14
    i want to get the motor in it running till i can get a different motor and its a b16 and i have a question do the raditor fans have to be hooked up for it to try and turn over? how do i leave yall for helping me?
  16. bjoebright14
    im trying to get it running first cause i think the wireing is messed up what shpuld i do
  17. George777
    George777 ^^ Likes Bewbies
    With your mom
    Bring the car and a blank check to a reputable shop and let them do it. That's what you should do. If you can't take the time to do some research and figure out what you need to do to get your stuff right, then you probably can't do it to begin with.
  18. cjvictoria
    N. Chuck, SC
  19. bjoebright14
    does the raditor fans have to be hooked up for the engine to turn over?
  20. 95b16coupe
    ct
    no
