91 d15b vtec need help
jls12388
doing a d15b2 block and d15b vtec complete rebuild
i got the obd0 to obd1 harness with vtec sub harness
my d15b2 harness ready for MPFI converison
4 wire 02 sensor
useing a virgin p28 ecu
d16z6 dizzy
buddy club vtec controller
the issue im having is i keep reading about wiring up a crank angle sensor do i need that on my swap and if so where is the crank angle sensor located at on the block
also the TDC Top Dead Center sensor is that in the dizzy or do i have to get one to wire up and how do i wire it up
i need a complete write up on DPFI to OBD1 MPFI and vtec wiring any info will help
