I have an 89 dx hb. I just got the complete rear brake assembly and e-brake line. I was just making sure this is all i need when doing the swap from drum to disc.
u dont need the whole suspension. all you need are the trailing arms and the e-brake cables. its better if you find some e-brake cables off of the 90-91 crx si w/ rear disc because they will fit better but the cables of the teg will work but you'll have some slack in them and your gonna have to find a way to tuck them under the car. and your also gonna need to use the arms that adjust the toe, off of your stock trailing arms i believe, and use them on the teg trailing arms.
