91 prelude h22 swap
Discussion in 'Prelude' started by dr.crankenstine, Feb 29, 2008.
  1. dr.crankenstine
    dr.crankenstine New Member
    I have a 91 prelude and i am attempting a h22 swap. i dont want to have to reset the homemade mounts 4 or 5 times trying to get it right. i want to know were i can buy motor mounts for a 91 prelude h22 swap. also find out if i can use any of the 91 mounts or exact demensions on how to make them.:huh:
  2. Uncle Buck
    Uncle Buck JDMDecals.com guru
    Spearfish, South Dakota
  3. jayludeh22
    jayludeh22 New Member
    3rd gen h22 swap
    There are mounts you can get they are around 375.00 to 475.00.I just bought a set .Im looking for a plug and play harness for this application if anyone knows where i can find this.If you need axles for this swap raxles.com has them for 360.00 a set.Anymore questions hit me up.
  4. Uncle Buck
    what year lude do you have???
    but look into Rywire they have what you will need
  5. 1Funryd
    1Funryd Member
    Here is the link to the most informative writeups for the H22 swap into the 3rd gen chassis:
    3rd Gen FAQ/Resources - Common Fixes, Manuals, Write ups, etc - Preludepower.com
    Its on preludpower.com
    As for the wiring for the conversion, uncle Buck is correct, just email Ryan@rywire.com and they can do the harness conversion for you.
    Mounts are sold through me since I had them produced and did all the nasty hardwork to get them produced.
    I sell the mounts for $475 + shipping and any paypal fees, but I also accept money orders.
    Anyone can contact me at: onefunrydperformance@q.com
    Or pm me thru here as well.
    And sorry but AZ Race will not give out that information for the dimensions, they worked to hard on this project to just give up all the secrets.
    Sean
    (206)304-4095
  6. dr.crankenstine
    i used 90 accord half shafts on my 90 lude h22 swap
  7. 1Funryd
    1Funryd Member
    Those work too, but some people have been known to break them.
    Sean
  8. h22yellowhatchie
    h22yellowhatchie New Member
    hartford ct
    i as well have mounts for this swap but your not going to find a plug and play...u need to make a harness out a obd 0 integra harness unless yours is obd 1
  9. 1Funryd
    1Funryd Member
    Or just send your original harness with the H22 harness to www.rywire.com and they can do it for you and then it becomes plug and play.
    I have done most of the work to make this swap as simple as possible within reason. Obvisouly if you do not have any experience then you should pay someone to do it. But i have had all the parts manufacured for mass production.
    Sean
  10. h22yellowhatchie
    hartford ct
    if i modify an obd 0 integra harness, will it still plug into the cassis plugs on the shock tower????
  11. h22yellowhatchie
    hartford ct
    also i was going to see if my 90-93 integra axels will work????.....
  12. Uncle Buck
    they might work for the hub side.... but the tranny side is way different.... different spline count
  13. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
