91 si hatch w/88 crx hf engine. need advice
Discussion in 'Civic and CRX - EF' started by matt thomas, Dec 23, 2010.
  1. matt thomas
    matt thomas New Member
    new to the site and messing with honda's. i had a 90 integra for years that never gave me much trouble. damn i miss that car, but thats another story.
    i recently bought a 91 si hatch with an 88 crx hf engine. i think its a d15b6? the car is in descent shape, no rust or bad body damage, descent interior. love the car! it runs pretty good, but its lacking power! im wanting to put a motor in that will get the car out of its own way. im not looking to make a race car here, i just need advice on what engine will be a no hassle swap and give me some much needed power.
    thanks in advance!
  2. hondafreak513
    hondafreak513 New Member
    O hi O
    put a 91 d16a6 in it with a few mods and you will be happy. And very easy to do. or you can go the b-series route but more expensive..
  3. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    I honestly would spend the extra time and money , which isnt much more and go b-series, alot more fun, alot more power, u cant beat it and its a fairly easy swap
  4. matt thomas
    thanks for the reply's guys. money is tight, and i just want the swap to be as easy and budget friendly as possible. with the d16a6 i can use the same trans, correct?
  5. dilbeckskate
    Kennesaw Ga
    do the dohc zc d16, it will drop right in, use same mounts, and same trans
  6. hondafreak513
    O hi O
    yeah the dohc zc is another great motor and drops right in and uses your trans. any d-series trans will adapte to and d motor
  7. dilbeckskate
    Kennesaw Ga
    well said, and they are both obd0 I believe so there will be no wiring problems, and I dont knw your area but here in atlanta they import the DOHC zc's at NAD AUTO for 650 with trans intake, dizzy and everything, drop right in, plug and play lol
    National Auto Distributors, Corporation
  8. matt thomas
    i really appreciate the info guys!
    i will try and track down a place in st. louis that imports engine's.
    thanks again
  9. dilbeckskate
    Kennesaw Ga
  10. hondafreak513
    O hi O
    The only bad thing is the HF trans has really long gears and will slow down the different motor. It is geared for better gas mileage. And if you do get the ZC dohc you will have to rewire the distributor plugs cause they are different and you will have to move wires out of the distributor plug to the external cam sensor.
  11. dilbeckskate
    Kennesaw Ga
    thanks for pointing that one out, totally wasnt thinking of that one, but still its a fairly easy wiring job, and plenty of forums to show how to do it
  12. matt thomas
    im not sure its an hf trans?? the impression i got from the seller was just the motor was swapped?? guess i should verify what trans is in the car now.
    thanks for the links dilbeckskate!
