'92 Air Conditioner Problem
LITTLE TEE
More often than not my compressor is not engaged. The unit blows warm air. It does work occasionally & blows cool air, but it usually does not. Is there a sensor that may be malfunctioning, or a loose wire?
Please help.
LOL, I have an a/c compressor for a 92 accord. wanna buy?
It may not be the problem, but still.
Usually when it cycles on and off, that means you are low on refrigerant. Take it to a shop to have it leak tested, or buy some UV reactant refrigerant and recharge the system, then take a black light and see if you see anything. Most leaks are caused by O-rings though, so you may not see anything. Your best bet is the shop though.
