92 prelude h22 swap no start problem
i have the same no spark no fuel problem cant figure it out bout to put it for sale replaced ecu cuz somehoe the other one just burned then the no spark no fuel problem happened originally jumped time then went down hill you still got that dizzy for 40
Before you go changing the dizzy- did either of you run a compression check? Do that. If you've got no compression on the cylinders in question, take off the valve cover and check your valves. Do a leak down test. Any oil in the coolant?
