93/94 Del Sol wont start !!!HELP!!! Please
Discussion in 'Civic and del Sol - EG and EK' started by cuabnjoe, Sep 17, 2007.
  1. cuabnjoe
    cuabnjoe New Member
    sebastian
    hey guys,:confused:
    i just got a 93/94 honda del sol with has a sohc vtec and i am having a really hard time trying to figure out why it wont start. i change the spark plugs, wires, cap rotor, fuel filter, checked the fuel pump and its pumping, and i put the clear cap on it and it really sparks, it will turn over but it will not start for nothing, and then i hought it might be the timing belt but its fine. so if anybody has a clue what might be wrong please tell me thank you...:confused:
    I would of check'd the fuses in the car and under the hood but they are missing (the cover that tells me what fuse goes where) so if anybody can send me a copy or a link where i can get a copy that would be great.:confused:
  2. Eros2180
    Eros2180 New Member
    Hagerstown, MD
  3. cuabnjoe
    cuabnjoe New Member
    sebastian
    thank you for the that info do you have the one for under the hood also by any chance.
    Thank You
    Joe
  4. Eros2180
    Eros2180 New Member
    Hagerstown, MD
    im working right now, check back in a few hours, if noone else has posted one ill put one up
  5. cuabnjoe
    cuabnjoe New Member
    sebastian
    ok that works i am at work also, im trying to get all the info i need so when i get out of work i can check everything i can, when i get home.
    Thank You
    Joe
