93 Eg Ls/vtec Questions
Discussion in 'HYBRID -> EG-EK / DC' started by EGLsVtec93, May 16, 2003.
  1. EGLsVtec93
    EGLsVtec93 Junior Member
    Im in the middle of building my ls/vtec and I need some advice from an experienced lsvtec builder. Will I be alright with this setup or will I wreck the motor after a few months?
    2nd gen b16a head
    90-93 b18a
    b18a rods
    b16a pistons
    honed/surfaced block
    surfaced head
    itr springs/retainers/cams
    b16a water pump
    b16a oil pump
    b16 timing belt
    Also can someone make me a list of parts that are REQUIRED for this motor or am I ok with what i've listed above???
    THANKS : MARK
  2. lsvtec hatch93
    lsvtec hatch93 Senior Member
    thats prett much what i had except for i think you have to use a b18c timing belt.
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    You should be fine with the parts listed. Personally, I would add ARP rod bolts to that, but I have seen builds like yours run well consistantly.
  4. EGLsVtec93
    im just confused about what timing belt to use i heard use whatever water pump i use and i have a b16 water pump so do i use a b16 timing belt?? also my friend is parting out his b16b is there aything i can use off of it for my lsvtec that are better than any ofthe parts I have??
  5. Supahatch
    Supahatch Junior Member
    You will use the b18c timing belt because the B16 timing belt is about 8mm to short!
    BTW: Good setup- Hope all goes well!
  6. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    I would also add a Z10 crank girdle, and like above some ARP rod and head bolts.
    Milan
  7. EGLsVtec93
    whats a crank girdle, where can I get it and how much is it??
  8. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Z10 Engineering
  9. lsvtec
    The crank girdle is not necessary, but it cannot hurt.
