94 civic ex brake lights stuck on
Discussion in 'Civic and del Sol - EG and EK' started by bannacrx, Mar 17, 2009.
  1. bannacrx
    bannacrx New Member
    hi ive got a 1994 ex
    rear spoiler light is always stuck on if the battery is connected
    when i turn the headlights on, the actual braking lights stay on like im always riding the brakes
    but the brake lights go off when i turn the lights off.
    only the rear spoiler light stays on
    i thought maybey the switch but that doesnt explain the rear spoiler light
    help! :\
    thank you
  2. murray195
    murray195 Member
    Calgary, AB
    Is the spoiler aftermarket? Have you changed the bulb recently? Have you done anything to your car recently to do with electrical?
  3. bannacrx
    bannacrx New Member
    nothing at all
    i just noticed it one day. never used to do it so im not sure what kicked it off.
    its a factory ex spoiler, but i do beileve it was swapped out for another stock spoiler, although it wasnt acting up previously.
  4. BlackFrog
    BlackFrog Neighborhood Lush
    North Freakin' Idaho
    sounds like feedback through the circuit. Sometimes the wrong bulb (one that works correctly but doesnt have the correct resistance) or a shorted wire can cause this. first things first you need to find where the power is coming from by probing the wires, since, for the brake lights for instance, its obviously not coming from the brake switch. Try pulling the park light fuse to see if the lights go out, or the brake fuse (if its a seperate fuse). Check your wires first where they go from the trunk to the car, as the opening and closing of the trunk can cause the wires to frey and short.
  5. serrilion
    serrilion In my own little world! VIP
    Vermont
    I'd say cut the wires to the spoiler and bondo it in, never need a light on it anywayz haha
  6. markspears
    markspears New Member
    Atlanta
    Easy Fix for Brake Light Issue
    There is a small, cheap rubber stopper on the brake pedal that actuates the brake light switch. Buy a new one at the Honda dealer. Less than $5.00
    That happened to me, too.
  7. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    You can also use a screw and a bolt instead. It's even cheaper. I had to do it to my last EG and it worked like a champ. :D
