i am going to swap the b18c1 into a honda civic. does the wiring harness from the 92-95 honda civic fit the 1995 gsr motor and is it a direct bolt in swap?
Yes the wiring will fit, but you will have to add a wires for vtec and the knock sensor depending on what ECU you will be using. With the aid a mount kit the b18c will bolt into your civic.
