acexxxoasis
Hey guys I'm having problems getting my bastard running (f22b2 head on f22a3 block) and I'm to the point where i just don't care anymore about getting this combo running got tps code vtec code misfire no throttle response past 2500 rpms yatta yatta yatta rebuilt head 4 tps 3 vtec solenoids and switches later I have now been working on the car for about a year and a half and I'm over it. so with that being said I'm looking to swap. The problem is I'm in so cal yall know the rest but i have a leg up and I work at a pretty decent custom shop out here with some good connections and I'm not sure what engine to choose! I can get any of 3 for around a grand each with harness ecu and trans included
H22a- dohc vtec parts are easy to come by good power but that's what everyone does! obd1/2
H23- dohc parts are easy torque is better still real common engine obd1/2
f20B-dohc vtec power rev friendly different almost a bolt in obd2 only
I like the helpfulness of obdII but converting car over might suck, give me a reason to gut it though...
I like the f20b,h23,h22 in that order any ideas comments suggestions?
thank you
-grease
thank you
-grease
