96' Accord Door Lock - HELP!
Discussion in 'Accord' started by atari52oo, Sep 3, 2006.
  1. atari52oo
    atari52oo Junior Member
    Portland, OR
    Help!
    My automatic door locks won't stop trying to lock themselves! When I hit the door locks, all of the locks will lock, and then keep trying to lock until I either push the button to unlock the doors, or I pull up on the drivers lock pull. The same thing happens when I lock the doors with the key from the outside, or I push down on the drivers door lock.
    Any ideas were I should start my troubleshooting? Could this be a relay issue? or maybe something with the lock pull inside of the drivers door?
    Thanks in advance for any help!
  2. TeamUrbanChaos
    TeamUrbanChaos Certified H22 Super-tech
    Home Of ThE LoSt Towers
    do you have some kind on keyless entry system on the car?
  3. atari52oo
    Portland, OR
    Well, I have an alarm that will trigger the cars automatic door locks..
  4. dens_310
    dens_310 New Member
    okay maybe the brain is going bad...?
    take them of the put it back to normal without the alam.... you have to do it fast
    because you can bern the motor.....
    good luck
  5. TeamUrbanChaos
    thats what i was getting at as well..usually the source of a failing power options (door locks, windows, alarm, etc) is usually contributed to a module or brain of some sort thats gone bad.
  6. dens_310
    dens_310 New Member
    i just said that...lol
