96 Accord Questions...
with the f22b, it should bolt right in, even to the tranny you have now. the h22a will also bolt in to the tranny you have now, but you'll have to wire in the vtec. or you could probably just run it w/o vtec. idk how that would work but it might be possible.
So there so be no wiring changes between the SOHC and DOHC??
or am I gonna need complete DOHC Harness & ECU?
I would like to just swap in a DOHC (link above) and factory LSD 5spd.
idk for sure about the wiring. i'm going to guess and say that the wiring is the same unless you're going to put a vtec motor in. unless you go between obd series. obd-1 wiring migth differ from obd-2 wiring and you have an obd-2 car. so to make it easier on yourself, get a 96 or newer engine if you can.
