bradsonthego
I have a 97 civic I picked up that had a 92 v-tech head swap in it that smoked and barely ran. I want to put the 98 integra motor I have in it but have run into an ECU issue. The car had an OBD I ecu in it to run the V-Tech. What ECU'S can I use to run the OBD II Integra motor in my civic EX. The integra wiring harness is a complete body and engine harness were as the civic harness is separate body and engine harnesses. Can you even run a OBD II motor with a OBD I ECU without doing major changes? And finally shouldn't this Integra motor [ 1.8 ] swap in easily?
Thanks in advance for any help you can provide!!
Brad
Brad
