I got pulled over last night and the cop told me my inspection sticker was FRAUDULENT due to the boldness in the bottom numbers and a miss-spelled word on the back of the sticker. so he then scrapes it off if my window with a razor and is holding it as evidence. blah blah now im beat...that inspection was good til 08 and was on the car when i bought it.
my problem is this:
b16a2 motor using the STOCK cx harness.
on the inside end of it, is an obd2-obd1 jumper harness with a p72 obd1 gs-r ecu running the car. I went to 5 different shops for inspection and noone will even touch the car. Ontop of it all, there is a test pipe (no cat). A friend gave me an ecu claiming it was out of his old 2000 civic SI. its a "p2t".... never really heard of it but ok....its like half the size of my p72 and has totally different female connections. i tried to put the stock harness into it, but there is a small connector that has a blank spot (capped with nothing in it) on the p2t ecu and my stock harness has the male plug that should be going into it. now my question is how can I run that p2t ecu to get my car back to obd2? do they make a conversion harness or do I need to buy a 99-00 civic SI engine harness? the only way ill be able to get it into inspection is pretty much convert it back to obd2 and put a cat on it and hope it passes....
my problem is this:
