98 Civic D16Y5 (HX) Engine into 98 Civic EX (D16Y8)
Discussion in 'HYBRID -> EG-EK / DC' started by mkst, Nov 17, 2008.
  1. mkst
    mkst New Member
    My D16Y8 is done and I can get a D16Y5 for a very good price but I am wondering if it will work with my current setup if I only swap the engine and retain my P2P ecu and EX wiring harness?
  2. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    The Y5 isn't VTEC, correct?
  3. mkst
    mkst New Member
    The Y5 is VTEC-E. Comes from the Civic HX. I was thinking I could swap over my Y8 intake and exhaust manifolds and it should run on the P2P ecu but I just want to make sure.
  4. tabKola
    tabKola New Member
    Tewksbury MA
    It will run like crap because the VTEC-E activates around 3000 rpm while the Y8 VTEC activates at around 5000, they also have very different fuel maps and are desingned for very different applications. You'd be better off either getting the right ecu or fixing the Y8.
  5. mkst
    mkst New Member
    Ok well if I get the correct ECU (P2N), will my EX engine harness work with that?
  6. tabKola
    tabKola New Member
    Tewksbury MA
    It will except for the EGR sensor (no connector on EX harness) and thats it as far as I know. Just make sure you get a P2N that matches your harness (harness should be OBD2B if car is a 98)
  7. austin20110
    austin20110 New Member
    Northern Va
    I would suggest any other motor than a d-series
