99 gsr swap going into 95 si
hammerdgolfer
ok maybe i should have searched for this but ohhwell, its a full 99 gsr swap, and my freind has a 95 si, does anyone have any tips on how to do this? repin the dist so it works obd1?will the obd2b injectors work?
whatever info you can give will help thanks alot
[post=371502]Quoted post[/post]​
if you have a full 99 gsr swap it will drop right in and plug right up... get the obd1 gsr p72 ecu and you will be good to go. You dont have to wire/repin anything...
I am assuming by full gsr swap you mean you also get the engine wiring harness for the gsr engine..
I just did the same swap on my 95 civic, here are the steps:
remove old engine
drop in the gsr motor (use the gsr mounts)
connect the plugs at both shock towers
Replace your current ecu with a p72 obd1
and run the pink wire from the IAB to a17(double check to make sure i think its either a17 or a19) at the ecu and the black wire to the yellow/black wire on the drivers side shock tower connector.. and your all set.
