A B Seires Throtel Body On A D16y8
Discussion in 'Engine Building' started by H0ndap0w3r, Jan 11, 2003.
  1. H0ndap0w3r
    H0ndap0w3r Banned
    will this fit. i want to put a b series throtel body on a d16y8 itake manifold. because i figure that im going to want to get it bored out, and if i bore a stock d16y8 intake its not going to be that big. but if i bore out a b16 intake or something like that it will be way bigger.
    but i dont know if it will fit????
    can u help???
  2. zueke
    zueke Senior Member
    Lansing, MI, USA, Earth...
    Well, easy answer... no.
    The blocks are totally different, and line up differently as far as I know. IF you did ever get it altered enough to make it fit, you would be losing all the benefits of having the larger throtle body, AKA you would need a HUGE adapter plate probably.
    As always, I may be wrong, and I am sure if I am someone like Pissedoffsol will correct me.
  3. knowledge
    knowledge Senior Member
    Beale AFB, CA
    B16 TB fit on D16Z6's. Not sure about Y8's though.
  4. cxjon
    cxjon Senior Member
    man+k+toe
    i knew of a person that had a y8 tb on a z6 so think it would work!
  5. jeffie7
    jeffie7 Wrong Whole! VIP
    Maryland
    I had my stock D15B7 throttle body on my B16 till I got my BBK throttle body
    yes the B16 throttle body is a good bit bigger then the D15b7
  6. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    yea it will physically line up, the only thing you have to worry about is the fast idle valve... it needs to be from the same generation... for example... 92-95 honda throttle bodies have a mechanical fast idle valve that waits until the coolant heats it up before the fast idle is bypassed, and the newer ones have the fast idle built into the ECU, when i put my ITR TB on , i lost all fast idle... SUCKS in the winter.. thank god it is garaged now.
  7. orangecivic
    orangecivic Junior Member
    I put a B20 CRV throttle body on my d16y7 and it ran great. I had no problems with it.
  8. RFHOMI2U
    RFHOMI2U Senior Member
    you have to play around with it. I'm almost positive that a B-series T/B will not fit on a D-series intake manifold. And No, All d-series T/B's are not interchangeable. First of all, it would be pointless (unless you were buying an aftermarket), next of all, the vacuum hose hook-ups will not be the same (yes, that is a bad thing) and next of all, why bother when you can easily bore a T/B right in your own garage?
  9. H0ndap0w3r
    H0ndap0w3r Banned
    ok thanks for the info
