yeah if u want a small bump in power, go with intake, header, and exhaust, a better clutch. then take out your power steering and a/c, which would free up hp, and unbolt all your heat shielding under the car. buy some motor mount inserts and get some decent lowering springs and better wheels n tires. get your ecu chipped and get tuned. and strip your trunk out. this will make a fun to drive car and a good start towards anything else u would want to do. and try to take out as much weight as u can. the lighter your car is, the faster it will go with the same power.
